It seems one of my pre-installed Antec TriCool case fans is on its way out. I have no idea what the current state-of-the-art is with fans, so a simple(ish) question:
What fans should I consider for best build quality (which I'm very happy to pay for) and a good balance of airflow and low noise as standard (i.e. no fan speed controllers unless they're supplied with the fan).
Current fan spec - using supplied speed controller - 1600RPM, 56CFM, 120x120x25mm.
Thanks.
Thanks.
