Caporegime
- 1 Mar 2008
I think this happens if they are in the create mode or have passed the "no more players" sign in their current level.
rp2000
Hearted you as a creator last night.
rp2000
Any idea if they're ever going to patch in the ability to create levels online with others? Am I the only one who thought you could? Quite disapointed with that.
I'm pretty sure they will, i think they didn't have time to fit it into the game before release or something and said they will add it in a patch later on
Opened some ports on the router and it still lags like a bitch. Almost to the point where online isn't any fun at all and that's a shame as online is brilliant the one time out of ten it doesn't lag.
I do wish they fix this soon...
Are you playing with randomers or OcUKers? Every time i play with randomers it's a nightmare, nearly every time i play with OcUKers it's spot on.
I'll have the game tomorrow. Would anyone like to help me through story mode?![]()
You don't have to. If you have the sticker that you need to stick, then it will show up in a new section called "Sticker Switches" just above all your others. If you don't have the ones you need then it won't show up.
At the start of each level I check if there is any sticker switches, and if so I keep a look out for any of that shape.
mint game, if you invite me i'll join as long as nobody invited me before
LOVE THIS GAME
(I have an ace idea, which knowing my luck already exists on the servers whilst I have been busy with Gears 2)
