- 23 Sep 2008
Might be interested in getting a p45 Board, but really confused with all the model number
Got about 100-120.
Cheers
Got about 100-120.
Cheers
I would defo go with gigabyte if your using ocz ram as some other makes including asus can be fussy about that companys ram.
I have a GA-EP45-DS5 and it has been without doubt the best motherboard i have ever had simple to use all the performance you need and those 10 sata ports are a real bonus though for me they were a must have. I have a Q9450 oc'd to 3.2 in mine with 8gigs of ocz vista gold ram in all four slots and the board had no problem picking up the memory straight away and it has run solid without a bsod or major crash since i installed it.
Many were recommending the P5q series and while they are good boards i can't see them being any better then the one i went with tbh. Only thing against mine is the price which seems a bit silly now being more exspensive then the extreme version of the board and due to the amount of features built into the board the bundle looks quite sparse when you open the box. If i was upgrading now i think i would still go with the DS5 although i would give serious attention to the xtreme version as well.
Waht about the newer UD3 boards? They seem quite nice. I tempted to go for eith one of those, a DS5 or an Extreme (This is same as the DS5? But with less SATA?).
Would just have to look at Offloading my x48 which might be an issue.
