I'm looking to replace the standard speakers in my MR2 with some newer stuff in the near future and I'd like to be able to discuss my options with more knowledgable people than the chavs I know who just want maximum volume and bass.
I guess this post is two fold, one asking for a decent car audio forum and the other to ask you guys for advice if you're in the know.
I'm going to need 6.5" component speakers for the front doors and 3.5" coaxials in the rear. Then I'm very limited with my choice of subwoofers, as my car is a T-bar I need to keep the space behind the seats free for placing the roof panels in when I have them off. This means a sub box behind the seat isn't an option (nor would I really want one tbh). However, what I have seen is this:
Now I'm not clued up on these at all, but I believe their called midbass drivers? Basically, my car comes with two very small subs under that panel anyway (that currently aren't hooked up), so what I would do is remove them and fiberglass that box section to seal it and then mount the new midbass drivers as above, but with a grille so I can still place the roof panels behind the seats.
I'm not looking for huge boomy bass anyway as I listen to rock and dance music rather than hip-hop or bassline and with the cabin being nice and small I'm hoping that two of those would do the job for the lower frequencies.
Finally I'll need an amplifier (or two) to power these 6 speakers, I'm open to suggestions on this.
So over to you, what would brands / models would you reccomend? My budget is flexible but I don't want to be paying anything over £400-500 and I'm not adverse to buying second hand.
