OK, so I've been putting together my pile of components for the odd couple of hours over the last few days.
Everything is in, but I now need to connect the power leads. So a few questions, if I may:
Spec:
Antec 300
ASUS P5Q-E
Q6600
PNY 8800 GT
4Gb OCZ (2x2)
Corsair HX520w
WD Caviar 640
Samsung SATA DVD
1 The 8 pin EATX12V socket on the PQ5-E has come with a rubber cover over 4 of the holes. Do I remove this and use the 8 pin cable from the PSU? Or, do I use the 4 pin cable from the PSU and leave the rubber cover on?
2 If I use the 8 pin (in 1 above), what is the 4 pin lead for?
3 What do I plug into the GPU? It came with a lead which I attached to the card, but that splits to two 4 pin connectors, each with only 3 wires / actual pins. What do these connect to?
4 As well as the SATA data lead and the SATA power lead, the HDD has 8 pins (2x4) on the rear. Are these for an alternative power source or something else?
5 What is the PCI-E cable for? It has 6 pins connector one end (PSU?) and 6pin + 2pin on the other end.
6 The fans have large 4 pin connectors (2 wires only). The PSU came with a lead labeled 'Fan Only' which has a 4 pin (2 wire) connector one end and then splits to 2 connectors, both with 4 pins (but only 2 wires).
7 Does it matter what is plugged in to which socket on the PSU (ie which of the 5 identical looking ones)?
8 The Mobo has a bright blue cover / sticker (which says EPU on it) on the southbridge heatsink. Is this meant to stay on - or should I remove it - which seems the sensible thing to do!
Many thanks
GM2
Spec:
Antec 300
ASUS P5Q-E
Q6600
PNY 8800 GT
4Gb OCZ (2x2)
Corsair HX520w
WD Caviar 640
Samsung SATA DVD
Many thanks
GM2
