Using this method, you can factorise to 2(y+1/2)(y-1) so, y=1, -1/2, since y=cos(x), the solutions are when cos(x)=1 or -1/2, so
cos(x)= 0°, 360°, 120°, 240° or in rads, 0, 2π, 2/3π, 4/3π
They're really the same solution. Exactly the same solution.
All your answers should be either in the range -π < x <= π or 0 <= x < 2π. Think about it, 2π away from where you start is back to the same point on the circle, as is 4π, 6π, 8π, -2π, -4π, and so on. If you're going to write 0 and 2π then you should be writing the infinite list of other solutions down. I'd expect you to lose marks for listing both, you certainly should as it shows a lack of understanding.
