I got an Asus P5KPL-AM with an Intel E5200, 2 gig of OCZ ram and XP pro. The motherboard has integrated graphics which works as it is supposed too. The other day I thought I would put in an Nvidia 8400 GS card as a step up from the integrated Intel G31 video.
Desktop and Windows Explorer use were fine but whenever I tried to watch TV or play video the computer would hang ending up in me having to reboot, (sometimes other software triggers off this fault but it is guaranteed to happen when opening up the TV card software or trying to run video playback.)
I thought this might be a problem with the card so I changed it to an ATI 4670. This results in the same problem.
The Asus board chooses whichever is set in the bios ie initiate PCI express or integrated or old style PCI so this motherboard appears to not need a specific ‘disable onboard video’ command but will switch between whatever video is set to boot first.
All the drivers seem to be installed ok and device manager sees no conflicts. The ATI card works as it should up to a point. It managed a 3Dmark06 score of over 8000 and works as it should with games.
Switching back to the onboard Intel G31 graphics adaptor will enable me to run video and watch TV and works perfectly.
I thought this was a conflict between the integrated and the installed card but now I’m not sure what it could be. Perhaps the power draw for video or TV is too much for my 450W PSU (although I would have thought 3D Mark would use a lot more juice)
Some headway. Did a full install of everything including codecs and the TV reception is working. Did dxdiag and it reported a Direct Show problem. Put the slider for hardware acceleration to the middle position for disabling direct draw and direct 3d and the card will now play video files.
This full install includes the November Direct X 9c, .net 2, klite codec pack, latest ATI drivers and Catalyst software.
When I test direct draw and direct 3d in dxdiag it passes.
Windows Media Player will let me play video with hardware acceleration turned on.
Is this just a codec problem? Sony Ericson PC Suite hangs the system too.
