2 mounting brackets each side and one going a cross with a silly like ball in the middle..How exactly does it mount on the phenom? Not had any experience of them - similar to socket 939 mounts?
gt
I can recommend the Noctua NH-U12P cooler. I managed to fit that with no problems at all, keeping everything respectably cool and most importantly is very quiet. I'm pretty happy with it.
well i've ordered the Arctic Cooling Freezer XTREME , so i'm hopeing it's better than my Thermalright SI-128. if it isn't i will just send it back and maybe get the above cooler.
oh well. ill see tomorrow when it gets delivered. fingers cross it'll be fineLots of people report that the AF7 was better than the Xtreme.
yeah but the Thermalright coolers all have the same mounting. also the hight is a issue because i have a 36cm fan on the side and i don't really wanna take it off..SI-128 is a decent cooler.. I think you would be looking at a TRUE for better performance
i know the SI-128 is a decent, i've already said that above. but i've explained why i want to change it + why i don't want another Thermalright.not all coolers are born equal.. the SI-128 is a decent cooler.. with out upgrading to a TRUE you are only taking a sidewards step at best
