- 17 Apr 2007
- stat city
Anyone have problems logging in to steam?
Also, who wants to play half life 2 L4D maps?
Do all of the below:
open /steam/steamapps/source materials.gcf
and extract the contents of /hl2/materials/ to
steam/steamapps/common/left 4 dead demo/hl2/materials
open /steam/steamapps/source models.gcf
and extract the contents /hl2/models/ to
steam/steamapps/common/left 4 dead demo/hl2/models
open /steam/steamapps/episode 1 shared.gcf
and extract the contents of /episodic/ to
open /steam/steamapps/half-life 2 episode one.gcf
and extract the contents of /episodic/maps to
steam/steamapps/common/left 4 dead demo/left4dead/maps
Server #1: 67.85.154.146:27010
Server #2: 67.85.154.146:27013
Pass: epone
Notes:
* Maps are on a timer, you will get an announcement before the map changes. If your whole team dies the timer will be reset.
* In the hospital map you can fall down into water. If you fall go to an edge and press space till you reach the top and get onto the stairs.
* You can see the sky at 2 doors, don't be alarmed, it's an Area Portal that is not opened correctly. Just go into it and it will be all fine.
Ravenholm:
I am aware that a lot of you would like to play Ravenholm in L4D and I am working on that. There are a few problems though:
* The first map crashes on load (There's a model or a texture that is incompatible with L4D).
* The map before the last is not really playable because L4D does not support swimming in water and you just fall to your dead when you jump into water.
Original Link:
http://forums.gamingterritory.com/in...showtopic=5640
Steampowered link:
http://forums.steampowered.com/forum....php?p=8427360
Enjoy!
