Q6600 Overclocking
15 Feb 2008
I just hoping for some advice on overclocking, i know theres plenty of threads but id just like to narrow it down...
i have an Asus P5N32-E SLI Plus and my cpu Q6600 ofcourse, with an AC7 Pro cooling it, could anyone tell me what settings i should enter in the bios, do i just mess with FSB? i really not sure.. hoping to get 3Ghz also could anyone tell me what temps they get with a Q6600 with an AC7 Pro thanks?
i also have a 1.2500 Vid ;)
That's a great VID you got there. Should be able to get a few more hertz out of that. Yeah, just play around with your FSB setting. I've only ever used gigabyte boards, and I have to set an option called "core host control" to enabled. You might have to do something similar but with a different name.
I have a 1.2625 VID on my Q6600 - currently running in a Asus P5Q Deluxe with an AC Freezer 7 Pro at 3420, Load temp is in the low 50's (core 0 and 1) and high 40's (cores 2 and 3) using prime 95, idle temps drop to low 20's :)
Oops - by low 20's I actually meant low 30's at idle (never post before you have had your morning coffee!).
:eek:Measured with what?
imagination im guessing
- OP - with a vid like that - i imagine 3GHz would be easy
you may not even need to go above stock voltages
try setting FSB to 333
and your multiplier to 9
obviously use a memory divider that allows your RAM to run at [or close to] its rated speed
come back and post if you have issues
Yeah, i should imagine so, thanks for all the input guys, ill give that a try but im just curious on what you mean by 'obviously use a memory divider that allows your RAM to run at [or close to] its rated speed' also on how i would do that? also ive just been in bios i found the multiplier, but couldnt find FSB does anyone know what that may be under on a Asus Mobo?
thanks
Your RAM speed is linked to your FSB speed, so as you increase your FSB, your RAM clock speed will increase. We don't really want that, so you'll need to lower your memory multiplier/divider/whatever it's called to keep it close to its rated speed. You'll see an option for it in your BIOS.
fsb is front side bus
or clock speed
clock frequency
or something similar
also be sure to turn speedstep off
c1e in the bios
This is quite embarrasing but i cannot find nowhere the FSB ive seen few things which says FSB but its set auto, and only options i get are linked etc. :S
post up a pic of your bios
or a list of every setting
then we can help more
enhanced C1 is disabled - this means speedstep
its your call if you want it on or off - i only turn mine on once i have a nice stable overclock
im not that familiar with that bios although i have used it before
leave the multi at 9
go down to overclock options and enable that [first pic]
then see if an fsb option crops up
you need to set AI tuning to MANUAL
then you get overclocking options
under that it says fsb and memory config
once AI tuning is enabled these options should be open to you
Ive done that mate.. in the Manual.. still none of the options come up to manually put the FSB up the only overclocking function possible is the AI Thing which in bios saves 5%,10%,15%+ etc.. but ideally i need to do it using the FSB right? for stability etc?
