Increase mpg by 30%, more torque and better audio
18 Jul 2006
Geneva
http://cgi.ebay.co.uk/POWER-BAR-mor...4&_trkparms=72 :1464|66:2|65:12|39:1|240:1318
- enhance fuel efficiency - saves gasoline (10-30%)
- increase engine torque - increase power (2-5ps)
- reduce car emissions - contribute to the environment unconsciously
- improve car audio sounds
- the small device cleans the entire car electrically including its body
- battery level check function: LED blue light for normal, LED red light for caution
- maintenance free, use up to 2-3 years (about 2,000 hours)
- silent, no more noise
- easy to use, simply plug into cigarette lighter socket
- power input: DC12V
- Size: about 3.5 inches (9cm) long
:D
oh my word!
they will now have people tihnking this can really be done via the lighter socket :/
Might as well buy one of those black earthing stips complete with white lightning bolt down it. Werd.
Seriously, no. Bad eBay. BAD!
Easy, uses booster electron charges throughout the car.
Just bought one.
You'll find its more to do with the gravitational field surrounding upquarks and down quarks which cause a positive discharge when a 12v dc bridge is applied across their electron tranameruons, throughout the car thus repelling dust from body work and increasing the explosivity of spark plugs. thus increasing power and fuel economy.
