After reading it's go I ran straight for the Zepplin at Org.......dropped out the sky and ended up falling through the floor in the Stonetalon Mountains XD
Well I noticed when I logged in at 9pm that my XP bar was moving. 1.5m xp to level up :O
At just gone 11 I cashed my dailies in and took the Zep from UC across. Did 1 quest before logging there - burning some bodies. Boars (lvl 68) with no rested XP around 875 and 20k for cashing in what was a very simple/quest. So they've doubled everything basically
Had a cheeky look at the grand alchemy trainer. Some nice things to make
The Death Knight creation is a little bugged, I was told (and it worked for me) create a level 1 character. Then create the death knight and should work. If not reload the client and then try it.
If you want to make a Death Knight but it says you don't have a 55+ (But you do) -- Create any level 1 character (You don't even have to load it up, just create it), then go back and create a Death Knight and it will work
Everything looks good so far - but I think I will enjoy it more when there are more people there (Northrend). Im mostly looking forward to seeing Dalaran
