- 9 Mar 2008
I think you ought to stick the values at +0.02v above their minimum - certainly on early BIOSes these boards overvolted by quite a bit, and setting the values to minimum manually was the same as setting them to auto (ie possible overvolt). +0.02v on top of the minimum is only a small overvolt, so should not have a massive impact on temps.
