- 10 Oct 2005
- Nottingham
Personally I'd run ntop under linux (the free windows version is limited on the amount it captures) and allow it to monitor the network for a while and see what it showed.
That will listen to the network and will show you which boxes are sending traffic to what internal and/or external hosts and how big this traffic is. It will also tell you what protocols are being used. This information is displayed via a nice web interface.
Of course that would mean that you need to have a linux environment running, (although a quick google seems to indicate that the SLAMPP Live CD seems to include it). I've never used this distribution (I normally have this installed a package on my SuSE server at install time) so YMMV.
More info.
This doesn't need anything installed on the other boxes.
Edit: also see here. The little bit of sleuthing he mentions would be look at the bandwidth usage by host summary table.
More info.
