Toshiba REGZA 32CV505DG
14 Sep 2007
West Yorkshire, England
Not sure if this is the correct place but anyway...
Scratch the idea I had of getting a monitor. I'm looking for a nice TV I can buy to play a PS3 on well.
Seen this TV "Toshiba REGZA 32CV505DG" for "£350" and "£362"(£12 delivery) including delivery. Was just wondering what your thoughts was on this TV and if it is any good? Cheers.
Not got bags of money so can't go much over £350.
I have an earlier model, the 32av505db and I am very pleased with it. I know its not a direct comparison but something similar.
I use it for Xbox 360, upscaled DVDs and Sky SD.
Here is a few specs:
Resolution : 1366 x 768
Display Format : 720p
Image Aspect Ratio : 16:9
Dynamic Contrast Ratio : 30000:1
Brightness : 500 cd/m²
Viewing Angle : 178 degrees
Pixel Response Time : 8 ms
Comb Filter : Digital
Features Auto Power Off, parental control, on-screen menu, Dynamic Contrast, ambient light sensor (ALS), DCDi (Directional Correlational Deinterlacing), front panel lockout, Active Vision LCD, Real Digital Picture, game mode, Regza Link, 3D Color Management
Connections Connector Type 1 x SCART (AV in/out / RGB) ( 21 PIN SCART ) - rear
1 x SCART (AV in/out / S-Video) ( 21 PIN SCART ) - rear
1 x component video input ( RCA phono x 3 ) - rear
1 x VGA input ( 15 PIN HD D-Sub (HD-15) ) - rear
2 x HDMI ( 19 pin HDMI Type A ) - rear
2 x audio line-in ( RCA phono x 2 ) - rear
1 x subwoofer output ( RCA phono ) - rear
1 x fixed audio output ( RCA phono x 2 ) - rear
1 x digital audio input (optical) ( TOS Link ) - rear
1 x composite video/audio input ( RCA phono x 3 ) - side
1 x headphones ( mini-phone stereo 3.5 mm ) - side
1 x HDMI ( 19 pin HDMI Type A ) - side
1 x S-Video input ( 4 PIN mini-DIN ) - side
Slot Provided 1 x Common Interface slot
Power Power Device Power supply - internal
Voltage Required AC 230V
Power Consumption Stand by / Sleep 1 Watt
Power Consumption Operational 141 Watt
The only thing what worries me if the fact there is pretty much close to no reviews on this TV like most cheap TV's.
Also is 141 Watt a lot?
I wouldn't go for this if you will be using it as a monitor, would try and find a 1080p set with a resolution of 1920xwhatever.
The tv is probably alrightish, but have a look for the sony 32 v4000, which in the first google match can be had for £376. Would be a much bettter investment than the toshiba, and I'm sure you could find it cheaper. Have a scour over at avforums.
141 watts is not a lot, don't worry about it :D
Everyone seems to recommend that Sony so I'd say it's definitely worth a look. That set the Toshiba Regza 32av (which I suspect isn't all that different from the CV) can be had for £320 and shouldn't be over looked.
It won't be for a monitor. It will just be playing a PS3 and watching some DVD's.
(not BlueRay DVD's as I can't afford them)
I have just seen the TV in Comet for £330. Can someone confirm if this is the same TV?
The sony can be had for £330, get that over the tosh.
Can't mention the store but it is a high street electrical retailer.
maybe some meteors tonight ;) :)
