Install port splitter, use port com2 (or which ever your GPS port is set to)
Use Baud Rate 9600
Output i use com6, add that then start PS.
In TT, use "Other NMEA GPS Device", Baud rate 9600 then com:6 Port Splitter.
Thanks for the help, but got a problem. In port splitter i cant write anything in output. I get a drop down menu which is empty and the keyboard doesnt come up so i cant wright anything there.....?![]()
I just bought one of these, £225 with it unlocked & in great nick. Good deal? Can't wait to start playing![]()
I could never get tomtom working 100% all the time with port splitters, plus they drain your batt if you forget to turn them off...
Switched to IGO8 and it works flawless, detects in built gps, no port plitters needed and locks in a few secs every time... well worth it
Yucca, if you click the start automatically checkbox and then exit, then restart phone, this sorted out the output port box being empty for me.
For those using Igo8, this might be of use, and its free
http://www.poiplaza.com/index.php?p=sdb&d=1162&lstpg=dc&lstc=42
Any chance of a walk through guide?![]()
sorry, its called autostart, under the output box, just above "about"
Well I pulled out of the Omnia deal (due to circumstance) & got a well-priced 16GB iPhone 3G instead, sorry for switching to the dark side![]()
The Peoples Front of Judea said:"SPLITTER!!!"
I have no start automatically checkbox?!!![]()
I have no autostart?! I have Input port above the about button.![]()
