- 19 Oct 2002
- Torbay, Devon, UK
DSL Status: UP
DSL Modulation Mode: Auto
DSL Path Mode: INTERLEAVED
Downstream Rate: 7072 Kbps
Upstream Rate: 448 Kbps
Downstream Margin: 5 db
Upstream Margin: 24 db
Downstream Line Attenuation: 37
Upstream Line Attenuation: 42
Downstream Transmit Power: 19
Upstream Transmit Power: 11
LOS Errors: 0
Im only on ADSL Max so 7mb is good, but I think I remember that if the Downstream Margin is under x then you can get instability.
Thanx in advance.
LOS Errors: 0
Thanx in advance.
