So dummies guide lads how do I go about installing Windows Vista Ultimate Upgrade when i'm currently on WIN XP 32bit.
You can create an ISO based on the files downloaded, burn this to a DVD then install a fresh install without entering a serial. From this install you can then upgrade to Ultimate using your serial.
Instructions for creating the image are here for anyone that has bought it online.
Microsoft encourages people to install the `trial` version, as many people who wouldn't go out and buy it, do actually buy it online once their month runs out. This is why they dont crack down on torrents of the iso's like other companies would do, you wont recieve emails from the BSA if you're IP address is on a Vista iso tracker. They unofficialy dont mind.
Just to clarify for my own stupidity, 1) create iso, 2) boot and install vista don't enter serial...You can create an ISO based on the files downloaded, burn this to a DVD then install a fresh install without entering a serial. From this install you can then upgrade to Ultimate using your serial.
3) now do I install over this from within vista or using the bootable iso again?
4) do I enter a serial number here, or wait until afterwards and activate?
Chances are if your in Uni etc your can get vista for free
No you cant.
Argh.Damn this thing.
Corrupt, can't install. 3.3GB wasted. Not mentioning the 1.2GB wasted when my Internet connection died the first time. And I didn't order the back-up media. Trying to find an option to do that now but I can't, anyone know where it is?
