just to be clear, its the northbridge voltage i will be increasing. ram voltage i have always kept at the 1.80v mark, by using the bios setting of ddr1.5v +0.30 to get 1.80v, everest confirms that memory runs at about the 1.810mark ish.
so i will first try 7-7-7-20 with northbridge volts at +0.050 and then i will try 9-9-9-24 at same +0.050 northbridge voltage if the 7-7-7-20 settings fail.
yellowbeard you ever had success at running 4 of these ddr3 sticks in a p35 mobo at 1600mhz before?
