Sky+ terrible picture on 37" LG LCD
Permabanned
26 Jun 2008
Hi,
I have just bought an LG 37LG3000.
Got it back and connected my Sky+ via scart and the picture on sky is absolutely awful. The freeview built in is loads better but still not brilliant. Why is the Sky+ so bad?
I cant connect it via HDMI as the Sky+ box doesnt have HDMI
Any Ideas?
Matt
Because you're putting a low resolution image into a larger resolution screen and hoping for the best that the scaler chip can cut it.
To make the best of what you've got, make sure you're using quality cables. Beyond that, get Sky HD.
A couple of things to try.
1) Go in to the picture settings of the sky box and make sure the output is set to RGB rather than PAL.
2) Buy a decent gold plated scart cable (the shorter the better).
Hi,
I bought a shielded scart gold today for £17 and put it in and the setting is on rgb
Still awful. Especially the faces , they look like cartoon characters.
Im thinking it might be the tv
If i cancelled sky and built a htpc and conected that to the tv by hdmi could i utilise the freeview built into the tv or not?
MAtt
Have you changed any setting since you got it home?, the factory default setting are known to be terrible. Do you have a digital aerial? that will improve the freeview picture.Is the TV set to receive the RGB signal that the sky box is now outputting? (I guess that the new scart is up to the job)
Hi,
I havent changed the picture settings. How will i know if its a freeview aeriel? , it found loads of freeview channels so thought it was.
Also, ive looked through ther settings and cant see anything about accepting the rgb signal?
Matt
Im thinking it is the lcd itself. Ive just read some reviews ans 3 of them are saying the picture quality is crap on peoples faces (same for me)
I might send it back and get this viera 42" plasma off ebay , that will be better quality wont it?
Matt
Matt
All the reviews on this TV that I've read have said how good the picture quality is, it's the sound that is a bit weak.
I have this TV and I am also using sky+ and the picture quality is way better than the built in freeview. Try the following settings that were recommended by Which magazine:-
Brightness 55/100
Contrast 89
Colour 65
Picture profile standard (user)
Sharpness 60
Backlight: 80/100
Tint: R4/R50-G50
Colour temperature: Cool
Fresh contrast: Off
Fresh colour: Off
Noise reduction: Medium
Gamma: Medium
Film mode: Off
Eye care: On
These TV's have lots of settings, the factory defaults aren't necessarily the best settings. Also, how close are you to the TV?
The SD picture quality scored 4/5 compared to more expensive TV's only scoring 3/5.
Have you compared the TV to other LCD's?
At the end of the day it really comes down to peoples preferences/expectations, I'm very surprised that you have not adjusted any settings to find the optimum settings :confused:
Hi,
Thanks for this.
Ive just changed the settings to this but dont understand the Tint: R4/R50-G50?
I can only change it to either r4, r50 or g50?
Even with these settings it still isnt brilliant. ive just turned the channel over and it had some trees in the background , the colour was just changing from dark green, to a lighter green , then a darker green all the time. Almost like its trying to focus?
Matt
Hi
It sounds like the lg picture processing isnt upto the job really i would think a panasonic plasma like the TH42PX80B would produce better results with sd material.
I would take magazine reviews with a pinch of salt you should look at user reviews on the avforums.
Hi,
Thanks for this.
Matt
To be honest, i wasn't sure about that setting myself. Are you saying that there are only 3 options available? I set mine to R4 but I could have set it to R1,R2,R3, R4 etc
Hi
The LG XD processing unit is supposed to be very good. I looked at a lot of LCD's before deciding on the LG and the reason I did choose the LG was because the SD picture quality seemed to be superior. Even my wife is very impressed with the SD picture quality and she takes some pleasing believe me ;)
Right... i did them changes on the freeview instead of sky. Derrrrrrrr
Ive done them settings now and it is better. So do i change the tint to r4, r50 or g50?
Matt
Try R4 that's what I have mine set to. Then sit back and just watch a few programs without trying to analyse the picture and I think you will find that the picture quality is just fine.
Hi
yes you are correct lg xd processing is supposed to be good with sd material but i seems to vary depending on the models and the lg 3000 range is the basic model higher end models seem to fair better.
