I have been asked by a client to supply him with 2 identical machines. Fairly low spec as they are to be used for one task only in a warehouse (monitoring cranes). They will be connected to a domain for access to the software required for the task hence I plan to install XP Pro for him.
The question is
1) Will I opnly need one copy of XP Pro as only one of the machines will ever be in useare any one time. EAch machine will be simply a backup of the other.
or
2) Does XP Pro cover 1-2 machines in any case.
I'm pretty sure that option 2 is correct but can anyone confirm?
Cheers.
The question is
or
Cheers.
