need to find info on XP login times
29 Oct 2002
London
usually i would go to event viewer > security but for some reason there is no info in there on my machine
is there anything else i can do to check the last few users that logged onto my Pc along with the time / date they logged in?
thanks for reading
type the command:
net user <username>
from a command prompt, that will give the users last logon time, if you're on a domain add:
/domain
to the end of the above command
Yes, usually the timestamp is the last logon.
Security logging wont always be enabled on default if you're on a standalone PC at home.
You need to run gpedit.msc and enable Audit account logon / Audit logon events.
Computer Configuration > Windows Settings > Security Settings > Local Policies > Audit Policy.
