Anyone got a spare old Sky card?
29 Dec 2004
I've just moved into a place with a Sky dish and cabling and the guy left his old digibox as he doesn't need it anymore.
It all works fine but I can't seem to get Channel 4 or
5 or Channel 4 + 1. I Googled around and I think I need a Sky viewing card (just any old one) which I know I can pay Sky £20 for but I'm 100% skint and just wondered if any of you guys had a spare one?
I'm driving from Norwich to Brighton on Thursday so could even pick it up and give you a quid?!
I'm not expecting much but it's worth a shot!
Thanks.
You don't need a viewing card. Go to add channels. Type in the values found here: http://en.kingofsat.net/find.php?question=channel4&Submit=Zap i.e.Astra 2D (28.2E) - 10714.00 H - Txp: 41 - Beam: Astra 2D DVB-S (QPSK) - 22000 5/6
and then press the yellow button on the channels it finds. Then you can choose them from the other channels menu.
Obviously search for the other channels and key in the details.
I think a viewing card will provide you with channel numbers, so you don't have to pick them from the menu though, unless that was some kind of limitation on the sky box i did this on the other day...
there;s the deatils for FIVE : Astra 2D (28.2E) - 10773.00 H - Txp: 45 - Beam: Astra 2D DVB-S (QPSK) - 22000 5/6
Oh ok I'll give that a try when I get back. Does this also work for Sky3?
I thought it was because 4&5 were scrambled and FTV not FTA (or something?!)
no if you read that website i linked, sky 3 is encrypted, but 4 and 5 are clear (unencrypted) If you get a card, you MAY be able to decrypt sky3 but I don't know and wouldn't care.
Channel 5 is encrypted, so you are not correct in this respect and you will need a FTV card
Well that website says Five is in the clear
Code:
[FONT="Courier New"]Astra 2D (28.2E) - 10773.00 H - Txp: 45 - Beam: Astra 2D	DVB-S (QPSK) - 22000 5/6 - NID:2 - TID:2045
		Name	Country	Category	Packages	Encryption(s)	SID	VPID	Audio	PMT	PCR	TXT	Last updated
		Five	United Kingdom	General	BBC Sky Digital	Clear	6335	5400	5401 eng 5402 eng 	256 	5400 	5404 	2008-11-04 +[/FONT]
I admit I don't have my receiver set up to test this just now.
http://en.kingofsat.net/find.php?question=five&Submit=Zap
Code:
Maybe it has just been added then
http://www.ukfree.tv/fullstory.php?storyid=1107051489
