How to attach yate looks to antec 300?
6 Sep 2008
Near Hull
Hi, i've just had 3 yate loon case fans delivered so can finally move my components into the new antec 300 i have. Only problem is the fans don't have screws with them and i don't seem to have any of the needed size.
is the anyway to attach them, even ?temporarily? untill i can get hold of the screws?
edit: dammit, stupid spelling on title, lol, yate loons not yate looks
You could use cable ties as a temp solution, however there could be a bit of vibration.
Otherwise i am not too sure, as i have always had loads of screw lying around due to the ridiculous amount of hardware i have bought over the years.
i have cable ties so that could be done for a while till i can get some screws, i do have some screws but none are the right size unfortunatly
Your replacing the ones that are in it? if so cant you use the screws you remove?
no, i have a new antec 300 and new fans i'm selling my current computer and buying a new intel instead of my amd, so just need to get the case all set up so that it's ready
edit: they're just a standard size screw right? i might have to take a walk to the locol computershop.
