- 9 Jan 2005
- Stoke-On-Trent
Hehe He's mine with a personal pic background.
Whats up with all the Ad's? I dont remember getting any Ad's. Anyway I'm currently using the Fable 1 theme I got with the HDD.
Have you got Xbox Live? Probably because you're not connected...
IIRC it'll be because his profile is set to under 18. Under 18 profiles didn't get ads last time I looked.
-Leezer-
Yep - as soon as you turn 18, they whip the ads on
Just deleted a lot of rubbish off my HD ready to install some games ;D
Same here, and playign through a plasma means i spend as little time as possible with the blades burning inI just have the standard dash, never bothered with themes or aby of that jazz![]()
When you look at the capacity is it a full 20GB? Mine is 13.3GB for some reason.. Still I have around 11GB left20GB HDD and I have 11.5GB left, not too sure if I'll be able to get that to 13.5 so I can have COD:WAW and Fable2 on it.
When you look at the capacity is it a full 20GB? Mine is 13.3GB for some reason.. Still I have around 11GB left![]()
