I've read that on the non-extreme versions the power draw is automatically capped at 130W, ie it will throttle down the multiplier whatever setting you choose in the bios if the power drain goes over this. From what i have read i think this is intel trying to get more enthusiasts to get extreme editions. On the plus side you probably won't be able to damage your cpu due to heat if you have a decent cooler.
you only need a core 2 clocked at 2ghz either dual or quad to make full use of ANY single GPU card out their ie 280's
Umm no
Quick example from last night. Helped my mate overclock his quad from stock to 3ghz. Gained 80fps in the source video test...
it doesnt matter what cpu u have as long as u have a any form of a core 2 cpu, you will get the same fps
its unfair to expect a cpu of any kind to make a difference in games. pc games are GPU bound and always have been. i remembered when core 2 first came out, it made little to no difference in games alongside the cpu that was faster before.
When will people realize that pc games get most of their resources from the GPU. you only need a core 2 clocked at 2ghz either dual or quad to make full use of ANY single GPU card out their ie 280's
Try playing as flight sim at any Res at 2ghz then 4ghz. The difference is huuuuuuge.
what else? most games are GPU bound. flight sim is cpu bound just like sop com
All games at a low res, all RTS at a medium res and a few games at high res.
And, not all of us have systems purely for gaming.
