Quick Question - Passat Cliamatronic...
You have two main modes, Auto and Econ.
Auto will do whatever it takes to reach your set temp so if that means turning the AC on then it will.
Econ will try and reach whatever temp you've set but can't cool any lower than the outside air, it won't turn the AC on.
So in short you need to make sure the display doesn't say Auto but it says Econ.
ok Thanks
My friend told me to make sure 'Econ' was off? - So what does it do with 'Econ' off?
Also - There are two temps on the display - What is each one for?
Gays the pair of you.
Only for you, 'hug'....
ok Thanks
Why do you want to turn the AC off anyways?
Long as Econ is on the display the AC will be off, this is all you need to know, technically speaking turning econ off will turn auto on which means the AC will be back on.
Did you actively accurately measure your 0-60 from a similer start with your aircon on and off in a 115hp passat? :confused:
Yep, six runs on an open road with ac on, 3 in each direction and the average taken.
Same again with the aircon off.
Data was taken at 1/100th second from the speed sensor in the wheels
