anywhere this spec looks dodgy?
Looks fine to me. I wouldn't bother with the Raptors tbh.. In fact wouldn't have a single drive either. I'd go for 3 of these in Raid-5
I take it you have a PSU?
yeh already got a good PSU, may as well use the raptors if ive got them.
any idea if you get fans with the case, looking to have the system as quiet as possible
Is it just as good? Only seen reviews etc of the other which looks great
edit: would be using onboard sound, is it worth getting a soundcard. got an old audigy 2 at present
cheers mate.
Whats the deal with the 4870 card, are the Nvidia ones much better?
Finally...would I be better off getting the next speed up on the memory or is this only really relevant when overclocking?
Ta
