Hi all,
I've just replaced my old A33G mobo with a Foxconn 6150M2MA-KRS2H mobo from OcUK. I built up the PC using all the same components from my old system (which was running right up until I powered it off for the upgrade). Tried running the new system and noticed that the CPU fan spins for maybe 2 or 3 seconds then stops. No signal on the monitor and no beeps from the speaker. I've checked all the connectors inc the power and 4 pin power. Nothing. Check CMOS, clear ir, replaced battery - nothing. I've even removed the mobo and run it outisde of the case with only the CPU and RAM (onboard GFX) to eliminate grounding and still the problem remains. Pulled the CPU and the connection between the CPU and heatsink is excellent.
Any ideas?
Any ideas?
