My Rig
Vista Ultimate x86
Antec 900 ( all fans set@high )
MSI P7N SLI PLATINUM nForce 750i (BIOS is updated to the latest version 1.2)
Q6660 @ 3.0GHz 1.328V with ARTIC COOLING FREEZER 7
(333x9) FSB 1333, Bus Speed - 333
Geil Black Dragon PC2-6400 800Mhz 4GB (2x2GB) 5-5-5-15-2T 2.05V
Palit 9800GTX+ 512mb
SPOINT 1TB 7200 SATAII 32MB NC
SAMSUNG 22X DVD+/-R/RW/RAM SATA
SILENT Win Power 750W ATX 20 & 24-pin Power Supply Unit
Hello guys I just built a PC on my own for the first time, bought all the components separately. Cost me £600 all in all ( is that cheap? =/)
Anyway tested it and its all working fine and stable but when i started overclocking the CPU i started to get NO POST, BSOD and unstable i know that's all normal when your doing a trial and error OC.
To tell you the truth I'm dissapointed about this motherboard as the BIOS dosent give me too much to overclock+ it wont let me overclock q6660 stable@ 3.3Ghz. The highest i can get is 3.2Ghz but to achieved that i have my Vcore to 1.5V+ to be stable. Cpu temp 35+-40+ idle and 50+-60+ in full load. is that any good? I've been researching the net about reviews in this motherboard and guide about overclocking. I follow all the guides but no luck i coudn't get 3.3GHz+ stable. Atm i switch it to 3Ghz to be stable for long time with less Volts. My current FSB is 1333 the highest frequency my motheroard support according to manual but i can increase it in bios maximum to 2400. I achieve 3.2GHz my increasing my FSB to 1430 and DRAM frequency to 900. I need to increase my Vcore to 1.5V+ and VRAM to 2.4V to be stable. NB V and SB V are increased my 1-2 notch as well.
Am i doing anything wrong in my OC? i know that my 3hz set up is safer than the 3.2GHZ. shall i stick to 3Ghz? or was it possible to achieve 3.3Ghz+ in this motherboard? or was it my memory's limiting the CPU to OC higher.Please I'm a newbie in overclocking any advise will be great.
Btw i only wanted to overclock my CPU so it won't bottleneck my 9800GTX+ when I'm playing a Game.
All my drivers are up to date.
Vista Ultimate x86
