Hi,
Just need a sanity check on the components for this. It will be a dedicated HTPC/media box running probably XBMC or Mediportal, From reading these forums I believe that the AMD 780g chipset is best for a HTPC?
I have an XP Pro licence which I will use on this box (4gb RAM is on the off-chance that I go to Vista early next year).
Basically I want the box to hold and stream all my avi and FLAC files direct to the TV (HDMI) and the Squeezebox (will be installing SqueezeCenter 7) - it will be located in the living room so it needs to be QUIET!!! Will the PSU be quiet and powerful enough?
Samsung SpinPoint F1 1TB SATA-II 32MB Cache - OEM (HD103UJ) - £67.99 x 2
Gigabyte GA-MA78GM-S2H AMD 780G Micro-ATX (Socket AM2) PCI-Express DDR2 Motherboard - £59.99
AMD Athlon 64 X2 Dual Core 5400+ 2.70GHz (Socket AM2) - £49.99
Antec EarthWatts 380W PSU - £34.99
OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 - £32.99
Keysonic Wireless Keyboard/Touchpad ACK-540RF - £24.99
Gigabyte GZ-M1 Black Micro-ATX Case No PSU - £22.99
Total inc VAT & shipping: £436.99
Any obvious changes?
Also can I just buy an MCE remote and use that with XBMC or MediaPortal, or would I need the Windows Media Center version of XP? Any recommendations for a wireless card / dongle so it can connect to my network?
Thanks in advance
Thanks in advance
 but the one above is the one i would buy, and remember dont buy it yet, the governments going ot lower vat to 12-15%
