Weird, looks like you have been hacked
Anyone recommend a scan...? ...Scanning with Adaware will see if that detects anything.Has norton hacked it?O/S Vista 64 running Norton 360.
try downloading a-squared i've found that to be better than my other anti malware apps. Download the 30 day trial rather than the free version though. Run that and see if it picks up anything. Also are you running the scans in windows or safe mode? Might make a difference.
What makes you think Norton is infallible?Shouldn't Norton protect against that![]()
i'm guessing you disabled UAC, then installed viruses on purpose![]()
. Other suggestions noted cheers.Shouldn't Norton protect against that![]()
What makes you think Norton can do anything right?
