firefox addon: don't store cache for sites i say
12 Feb 2006
Surrey
been looking for an add on which ets me specify which sites to not store the cache on e.g. localhost, but can't seem to find any. is there any that can do this? i have to have cache disabled as i'm working on sites on my pc but this gets very annoying then when viewing sites like this at the same time.
You can disable the cache completely with Web Developer, but AFAIK there isn't one which will let you specify a list to bypass the cache for.
thats how i disable it atm but it isn't ideal for when browsing sites and working at the same time as i'd be forever enabling and disabling it.
hoping someone knows of something that can do what i want.
Can't you just create two Firefox profiles, one for developing, one for normal browsing?
Change the shortcut for the second profile to:
Firefox -P Profile2 -no-remote
So you can run two instances at once.
