I'm not sure how many people here are aware of this matter, but it turns out that motherboard warranties are not as comprehensive as one might reasonably expect.
Specifically, motherboards that are burn-damaged beyond repair by components failing (exploding/melting/catching fire) are excluded from warranties by at least two major manufacturers. I've stumbled on this matter on a thread on the DFI support forum, and I thought it might influence some people's choice of motherboard (it certainly influences mine, even though I've never actually had a motherboard fail in such a spectacular way), so figured it could be of interest.
After all, knowing what the score is will hopefully save some long-term aggravation for both customers and the proprietors of this forum.
Here is a link.
Summary: Both DFI and Asus exclude such secondary burn damage on the motherboard from warranties, even if it was caused by failure of a component that would in itself otherwise be covered by the warranty.
(Note: No plugs to retailers, only component manufacturers.)
Here is a link.
