- 25 Sep 2008
Hi there
I'm looking at getting a Core i7 920 with 6gb of PC3-12800 (1600mhz) DDR3 Memory and an Asus P6T Motherboard
I was thinking about overclocking the CPU to around 3.4-3.6ghz, as most people seem to say the i7 will run fairly stable at this speed and the PC will most likely be running 24/7
I was wondering what the options are as regards to getting the memory to run at 1600mhz... as I've heard the P6T only allows for a memory multipliier of 6 or 8 - meaning you would have to run the BCLK at 200mhz to achieve 1600mhz (200 x 8), which would make the CPU run at 4ghz! (200 x 20)
This is how I understand the multiplers for the memory & CPU to work with the BCLK as an example... please someone correct me if I am wrong here
Has anyone got examples of what speeds, multipliers & voltages you've got your i7's and memory runnning at and what memory & board you've gone for?
Thanks
Thanks
