Max voltage for a E2160
26 Apr 2008
Bristol, Old Blighty
Okay, suppose I'm using liquid nitrogen or something and heat isn't an issue. Is there an upper limit on how many volts I can push through this chip? Like if I put 2 volts through it, would I knacker it even if it didn't overheat?
Sounds like fun! These chips love vcore and from what i have read, as long as the temps are fine (!) then there wont be a problem. I could be corrected by someone who has tried at 2.0v.
Seems funny doesnt it, u worry about putting a measely little 2v thru a CPU but not about dropping subzero liquid nitrogen onto it :D
I'm not actually proposing to use liquid nitrogen, it's simply a thought exercise based on the premise of heat not being an issue.
Have got mine to 3.769 GHz @ 1.73v on air :eek::D on a superpi suicide run. These chips are awesome and can take an electronic beating unlike their newer 45nm brethren!
It's rock solid at 3.33, I'm going to see how much further I can push it at 1.8. I'm not going to DARE put 2v through it :D
Alas, at this level, it goes 1.6 -> 1.8 -> 2.0 with no granulation in between. 1.6 is too weak, 2.0 will make my computer melt. 1.8 it is.
Brb, tinkering with BIOS...
Okay that failed. The chip will go no higher on 1.8v it seems. Tried 3.42, it POSTed but failed to load Windows. Ah well.
I got to nearly 2v on a e2180 and my water held the temps fine but didn't help the clock. Wouldn't post at 3.8Ghz.
I cant get mine stable over 3.2GHZ regardless of whether i go above 1.55v or not. Increments on my gigabyte board after 1.6 are 1.8 and 2.0 with nothing inbetween and at 1.8 it fails after post and at 2.0 it wont even post. Can boot into windows at 3.4GHZ 1.6v (1.575v in CPUz) but it fails under orthos.
Shouldn't need that much voltage on the CPU for that clock. What ram divider are you using? Have you tried increasing the volts on your NB slightly?
My E2200 is pretty much the same. Still, a whole extra gigahert makes quite a difference :)
Just had a wee crack at mine, 9x380 (3.42) seemed to be stable at 1.55v.
9x390 (3.51) at 1.6v booted into desktop before crashing loading the carp in the sys tray, RAM was at 1:1.
Back down to 9x333 for 3.0Ghz at 1.375v now, which has been perfectly stable for me since may. One thing I did notice was that vdrop is 0.05v, vdroop was another 0.02v, when testing at 1.55v.
