Hello
Ok i need some honesty from you antec 1200 owners out there.
Having had the case for as long as you have, do you ever wish you went for a lian-li or silverstone instead?
Feel like your case lacks class and your getting bored of it?
Im planning an upgrade you see, and the antec 1200 ticks all of the boxes for me. Great airflow, great cable management potential with a bit of work, is big enough for future upgrdes/wc and looks pretty good. The reason for this thread is that becuase they have the same sort of design, i fear the same happening with the antec 1200 as with my antec 300 in that i start to get bored of it after a while and long for a more classy looking case such as a lian-li model.
The reason i dont just buy a lian-li is because although they look very nice, i think they lack airflow and cable management a little bit, particularly the ones i like the look of, and im very fussy when it comes to cable management so its kind of a must.
So antec 1200 owners, i know its personal prefrence really and abit of an odd question but what would you do?
thanks
thanks
. Completely unimpressed by Antecs and Coolermaster cases (at least Antec are cheaper than Coolermasters), good on paper and tick all the boxes, but quality build is just not anywhere close to Lian Li
