£2000 i7 upgrade ?
Permabanned
19 Oct 2007
can you check this please ?
the top ocz ram kit is 6x1gb for tri ram optimisation, does that mean i can run 2 sets of 3x2gb kits ocz kits ? hence 6x2gb
this is what i got so far :
Also wondered if all that will fit into an antec 900 case ? If not can you recommend another case ? thankyou
According to your sig you already have a GTX 260, why spend that money just to get the maxcore version - you won't notice the difference.
Also £469 for RAM... some people have too much money.
And any particular reason for the 1000W psu?
And yes that will all fit easily into the Antec 900.
Corsair 6GB DDR3 Dominator PC3-12800C8 1600MHz (3x2GB) Triple Channel DDR3 (TR3X6G1600C8D) - £293.74
Intel Core i7 920 2.66Ghz (Nehalem) (Socket LGA1366) - Retail (with Far Cry 2) - £276.11
Foxconn Renaissance Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard - £270.24
Corsair TX 750W ATX2.2 SLI Compliant PSU - £82.24
BFG GeForce GTX 280 OC 1024MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail - £370.74
GRAND TOTAL = £1,246.50 delivered.
Will run just as fast in my opinion. SLI is good for some things and crap for others.
