Not possible to run it as my HDTV only does 1360x768 (2 years old 720P model) or 1920x1080i.AWPC, what do you get in the crysis benchie with the Q9450/260-216 at 1920x1200 (min, max and avg)?
Thanks
Too much trouble mate I do not have a 10ft long DVI to HDMI cable and cannot be bothered to swap PCs around right now as cable management is time consuming to undo.Is it too much of a mission to plug your monitor into it then?
Just that the really big question that seems to be kicking around here is the possible benefits of the i7 set up for gaming at a decent res. You would appear to be in the position to do a proper 'back to back' test.
I'm sure the forum would be really grateful!![]()
But what I will do is run the tests on the Q9450 @ 1920x1080 as thats close enough to see the FPS difference.
Tried Devil May Cry4 benchmark and the difference was actually too close to call. Q9450 ahead by 2-3 FPS in benchmark 1 but then falls behind by up to 50FPS in the other 3 benchmarks.
Not bothering for now as its way too fast at stock & I have no need to push it for anything plus not looking to pay £60-65 for a decent HSF as the Intel stock model is awesome for my needs right now with AS5. Check out: http://www.xtremesystems.org/forums/forumdisplay.php?f=56awpc: Any more results with regards to overclocking?
I get 3,062 @ 4Ghz so i guess that would be 2,373 (3,062/4*3.1 - assuming its linear) so thats 20% faster clock for clock. I guess the gains are in the high OCing of the i7.
I would be interested for someone with an i7 chip to run the built-in WinRAR benchmark (from the Tools menu). From 3.6 onwards it is optimised for multi-core systems.
On a Q6600 @ 3.1 I got 1,959.
(if someone could run the bench with an i7 at the same clock speed as me, it would be interesting to see the clock for clock performance difference)
