***OcUK 3Dmark06 TOP list MK2***
30 Nov 2007
**3Dmark 06**
As i mentioned in a provious thread I have decided to make my own database for Futuremark 3Dmark 06. I know that Ocuk member " marc2003 " has one set up but i seem to remember him saying recently he had to sell is rig and is updating when he can via cyber cafe.
so.
feel free use this until marc2003 gets back online with a regular update schedule.
Until I iron out ONE small problem you will not be able to view the database via the form. But you will be able to very soon.
I will update every sunday after 8pm, and post a table here.
I will run a OVERALL GPU and SINGLE GPU, DUAL and QUAD CORE CPU )
06 test is exactly the same as before. No AA, default Res
If you are not sure what 3Dmark06 is or you dont have the application, have a look here http://www.futuremark.com/benchmarks/3dmark06/introduction/
Please fill out all feilds on the form.
If you have any questions or suggestions please let me know.
For this I will allow beta driver tests and official drivers, if you cant create a compare link please post image of test results, failure to do so and I will delete your result,
Submit your results here http://creator.zoho.com/mosleypup/copy-of-futuremark-vantage/form-perma/benchy_form/
View your results here http://creator.zoho.com/mosleypup/copy-of-futuremark-vantage/view-perma/benchy_form_View/
** im no database guru, its basic, and its all we have at the mo**
ENJOYUS :p
Slight Edit: makes more sense now I've seen your other post. But I suspect all these new "Top Lists" are going tho get a bit messy!
I'm not trying to have a go but you'll get more responses and it will probably be much easier for you to manage, if you spell out clearly what is required.
It's not that clear for those who aren't familliar with the old threads/benchmarking
Will you be adding shader clock/cpu speed?
Something up with orb tonight? my results keep getting deleted.
results are up.
until i have a reasonable ammount of submitions i will just post an overall table.
any questions let me know
