- 16 May 2008
- Bristol
test
test678
test678
****ing idiot do your home work!
Look it up on Google there are loads of articles covering this or better yet ask your GP about psychosis.
In terms of estimated rate ratios, persons who develop cannabis-induced psychosis are as predisposed to schizophrenia spectrum disorder and other psychiatric disorders as those who develop schizophrenia spectrum disorder without a history of cannabis-induced psychosis.
Altogether, these findings, in addition to those of previous studies, indicate that cannabis-induced psychosis may not be a valid diagnosis but an early marker of schizophrenia.
Rather, the degree of hereditary predisposition in individuals who receive treatment of cannabis-induced psychosis closely mirrors that in those who develop schizophrenia with no history of cannabis induced psychosis. The results agree with those of other studies that show that cannabis predominantly causes psychotic symptoms in those persons who are predisposed to develop psychosis or show signs of psychosis in the absence of cannabis use.
Lmfao find me an article that 100% completely proves that it can. All that it says it that it may![]()
Isn't that a confession?FWIW I smoked every day for 10 years starting aged 16, have taken mushrooms and acid on numerous occasions, spent a lot of time in Amsterdam, even taking part in the Cannabis Cup as a Public Judge a few years back, smoking some of the most powerful strains of skunk, the same strains of powerful skunk that the media use to whip up hysteria about the drug reminiscent of the "Reefer Madness" campaigns of the 1930's.
Isn't that a confession?![]()
It's harmless if used with caution, don't mix drugs with other drugs or with alcohol, and do it once per 6 months at most on a medium dosis, afaik if you keep to these rules it's fine...
[DOD]Asprilla;12986136 said:Ah, fair enough. Having done a bit of reading I see you are right. However, it does say that they are closing 20% of them in all.
Cocaine is extracted from coca leaves, and is thus effectively natural: all the extraction does is concentrate it. Otherwise you could just chew the leaves, as many in South America still do. .
Heroin is a little more complicated: it's made be acetylating morphine, which is of course, extracted from opium poppies - see above. Once inside the body it it converted back to morphine within minutes: the rush is actually from the morphine, not the diamorphine that is the parent compound. So it could reasonably be argued that this is pretty much "natural" as well.
Of course MDMA is entirely artificial, so I assume you're in favour of banning that?
M
