Just got home to see my 4gigs of new laptop memory had arrived.
Grabbed my screwdriver and tried to unscrew the single screw holding the memory cover in place. Wouldn't budge. I tried so hard that i have actually damaged the screw. Causing a 'stripped screw head' i do believe.
I definately wasn't going to be defeated by a tiny screw so i decided to take the back of the laptop off to gain access to the memory.
I start unscrewing one by one the MANY screws holding it in place. And then i get to the last one, and surprise surprise, it wont budge. I didn't go crazy and try and get that one out to avoid possible damage.
So, how do i get this initial screw out? It's firmly wedged in place (probably down to a retarded Dell system builder), and after my efforts its stripped and retains no grip of the screw driver.
I've read about screw extraction tools. But for such a small screw it seems over kill to buy £20 worth of equiptment.
I could physically force the cover off, but i'm guessing finding a replacement would be tricky.
Any idea's??
Any idea's??
