Unstable E2140 need lots of advice
26 May 2006
Edinburgh
Having loads of trouble with this E2140, if anyone could take a look at my settings and point me in the direction of where I am going wrong.
thanks for looking.
looks like the ddr voltage failed.
is your memory running at 667 or 800? if 800 u need to underclock it so u can get a stable overclock on your cpu
At a guess, it looks like you're pushing the RAM too far (timing wise). 2gb sticks usually run at 5-5-5-15 or 5-5-5-18 and yours are running at 5-3-3-15. What sticks do you have?
1. PCI-Express frequency wants to be locked at 100mhz
2. Looks like you have 667mhz memory and are trying to run it at 800mhz?
3. Memory timings are too tight.
4. System voltage control should be set to manual, on auto the settings you've entered wont be being used.
PC won't even boot now, awesome.
With one stick of RAM in it powers up but there is no display.
With both sticks it powers up for 1 second and then reboots its self.
Trying different combinations with no success :(
so yeah you need to drop your fsb to 333and lock the ram at 667 or lower using 1:1 also set your timings to 5-5-5-15. should see you up to a 2.66Ghz clock with the 8multi.
you ram is holding you back on getting anything more from that cpu.
As Gunda said, the RAM is limiting you, I wouldn't be surprised if it's now fried itself from being run at 800mhz with such tight timings. If it is goosed and needs replacing get some DDR2-6400, then you can safely run the RAM the way you were, after slacking the timings off to manufacturers specs.
Yep, think you are spot on. Going to buy some new ram to test with from a local pc shop.
Ok it was definitely the memory, just bought some cheap DDR2 800 512 stick for £10 and the system booted with no problems.
Currently running memtest, looks like everything is fine. Didn't even get past 1% last night without like 127errors.
Tempted to take this 512 stick back and just buy two 1gig stickers of ddr2 800 and try overclocking again. Will RMA the old ram and just ebay the replacement sticks.
My memory voltage is at +0.2v, and the bios health status page doesn't say fail! It says OK!:D
I have an old 965p ds3 and it does it on that for sure. Didn't fully read the thread and after reading it properly he's obviously duffed his RAM in, that's why it says fail. But the older gigabyte boards have this bug.
