- 24 Oct 2002
- Portsmouth
Hi guys
I'm upgrading the kitchen tumbledryer and want to fit a vented tumbledryer. The tube will be going through the wall to the back garden.
Normally I'd pay someone to do it for me, but it's not hard and I figure I can do it myself easy enough with the right tools. The only question mark is the tool.
I know you need a Core drill bit set and was wondering if this would be suitable for a 4" pipe
http://www.amazon.co.uk/Silverline-Tct-Core-Drill-Kit/dp/B000LFY4Q0
The reason I ask is I notice the more expensive models have deeper bits, so would that set be enough to the cut through the bricks or am I better investing more money in this kit
http://www.amazon.co.uk/Silverline-Diamond-Core-Drill-Kit/dp/B000LFW46M
Any ideas? Bare in mind I only need this kit for the one job as it stands so if the first kit will do then this makes more sense being half the price.
