Hey all,
My review for this will be on the Overclockers webby once the admin clear it. I am very impressed, the build quality is very good and thoughtful. Before in my old case I had to have the X2, normally speaking, on around 40% minimum for idle and much higher for some games. Now, what the temp was for idle is now more or less for in game! Therefore no vacuum cleaner noise.
At one point two of my cpu cores were in the mid 20's, the highest core temp with all fans set to low and no windows open is 38C and its o/c too.
Dead chuffed. If you like the look of it, I appreciate not all will, then I wholeheartedly recommend one. Cheap 'n all. PC upgrade complete at last.
Tell a lie, need a bigger monitor for my X2, 2 raptor hard drives and a bluray player
