For that price I'd say so.
Check this out
It compares the GTX260 216 against the original GTX260... there doesn't appear to be that much difference unless you are buying a super clocked (or greater) version.
narr go for the 280GTX, you know you want to... I did and it rules
You would have to be a right muppet to pay the extortionate price for a 280 when you can buy a 260 maxcore and clock it to 670 on the core and get 280 performance and in some cirumstances beat a 280, like I did.
Is that a new price ? Cant find for that anywhere !!
With B-Grade you tend to get just the hardware, no extra at all (cables, manuals, drivers, CDs, software etc).
Hades, you have mail![]()
Unless you are fussed with FarCry 2 and Crysis, the original GTX 260 should serve you well. The GTX 260 216, especially the super-clocked versions, does seem to give you the necessary boost for a smooth frame rate at higher settings.
Even if you are fussed with FC2 and Crysis,the 260-192 still seems perfectly capable at 1920x1200,the Firing squad analysis has an average of 35fps in FC2 at very high with 8xAA,lets face it who needs 8xAA at 1920x1200,realistically 4X should be enough for anyone,average framerate at 4X would probably be well up in the 40's/50's.
At the B grade price I'd say it's definitely a very good buy.
