Don't pay for crap like this please ... an anti virus isn't suppose to be real slow and crap until they bring out a 'gamer' version. Anyone used this waste of binary?
Stick to AVG, Free-AV or NOD32 if you wanna fork out money.
And you've used this version? They're not saying there old version is crappy they're saying that this version is aimed at gamers and makes sure that if you're in the middle of the game that stuff like scans, updates, etc. are delayed until you've finished. Yes you can manually turn them off but a lot of people would forget.
An antivirus, primarily, is for security. It doesn't matter how fast your PC goes, how great you can play games it matters more, surely, that your PC is secure.
You can get AVG, AVast ant many others which are fine (though personally I wouldn't touch them with a barge pole). But remember that they also do payed for products. So you have to ask yourself what the difference is between the payed for and free products - I mean if the free versions were just as good as the paid for ones then surely all Enterprise customers would use them. However they purposely delay new definitions, horrid support and a multitude of other ways to get you to pay.
The updates would cause problems as it uses any and all bandwidth to obtain them and then updates the database. Simply changing the update schedule to first thing in the morning would be the best idea.
I, personally, use Symantec Corporate edition which is superb. I have, previously, used Norton and had no real problems with it. It does what it says on the tin and for the less savvy people out there takes a lot of guess work out of AV and security.
M.
