Bear Cavalry vs Skeleton Army
There's always a way in. how do you get into it youself if there wasn't? ;)
If in doubt, nuke it. Repeatedly.....it'll crack eventually.
Do you really think I'd build an impenitrable bunker that could crack under a constant barrage of nukes when we live in a time where Nukes are one of the most abundant weapons of mass destruction?
I think not!
You're right. The demolisher comes with the shovel attachment. It's been a while since I played :o
No no no. The 'dozer blade was an option on both. The Demolisher came fitted with the high calibre Demolisher siege cannon which had a very short barrell length.
The best variant was the one I made using the super heavy flamer from the Hellfire mounted to the Leman's turret, a hull mounted heavy flamer and heavy flamer in each of the side sponsons. :D Kill it with fire!!!
There can be only one...
How so It's Immovable, Impenetrable in fact I do believe the only thing that could beat it (If it exists sorry fundamentalists) is GOD
edit: or my fogetfulness which could lead to me leaving the door open.
If an unstoppable force meets an immovable object, it stands to reason that the immovable object must yeild in some way other than by moving. The force cannot be stopped and the object cannot be moved so the force does not stop yet the object does not move. Thereby the object yeilds to the force yet does not move.
So: unstoppable force > immovable object
