sound cards??
I suppose it depends how you use sound on your PC; do you use it for things like music, or gaming?
If you don't do anything like that then I'm sure the onboard sound would be good enough. If you game then a good sound card can make a big difference in sound quality, although you can definitely do fine without one.
i use my pc for gaming mostly my mobo is Asus P5Q Intel P45 (Socket 775) PCI-Express DDR2 Motherboard
so will onboard do for the sound?
The onboard will certainly do the job but you will benefit from greater quality if you got a decent card and paired it with some decent speakers.
Getting a sound card is regarded as an upgrade, but I suppose it depends whether you want to spend the money or not.
Depends whether you needed speakers I suppose, there's not much point splashing out on a decent sound card if it's just going through basic £7 speakers or something.
If it was me I'd allow something like £100+ for a good card and some quality PC speakers, it depends on what level of quality you want. You could spend less than that or you could spend a whole lot more.
Perhaps a speaker upgrade alone might be a better option?
I agree with the guys above, only get a sound card if you've got a decent set of speakers or headphones, otherwise it's wasted. Onboard sound is much better these days anyway, which should be fine for what you need. I mainly upgraded mines for music and watching movies.
If you do plan on getting a sound card, I'd suggest spending around the £60 mark, something like this
http://www.overclockers.co.uk/showproduct.php?prodid=SC-002-AS
About £60
On board sound is still pretty dire now a days
Even an old creative card for £5 is better than onboard. Onboard is ok so long as your not intending to use it for music, games, films.
Eh? You're talking carp. Onboard sound has come a long way.
I think your talking carp ;)
Onboard in my experience is low quailty, but then if you listen to music, films, and game through a pair of £2 speakers I guess you wont know any difference. :)
So in theory it's no good? lol :p
For £30 or so and you actualy use your pc for audio then I think its the best piece of kit you can put in your pc.
Ok thanks for that.
