upgades advice wanted
27 Nov 2008
firstly hi all .now then i was looking at upgrading my gpu when after reading a few threads on here about them i discoverd i may need to upgrade my psu as well the problem is i onley have about £150 to spend on them both what would u guys/gals recomend for this type of upgrade
cheers luke
What is your current spec, including PSU and wattage.
Welcome to the forums, remember to check the FAQ :)
Easy, just do-up 4 screws which hold the psu to the case, hardest part is making the cable route neat.
Which case have got.
i'd check the size of your psu currently. i know in the past they used smaller psu's sometimes in packard bell's and so forth.
